Retired_Member
Nov 26, 2021RAX-120: android devices fails to obtain IP address
Hello, I Just purchased the RAX-120, set it up, all my home devices connected just fine. I went to device manager, renamed a few (including the device which now fails to connect ), a hour later the...
Nov 26, 2021Guru - Experienced User
Anytime there's an issue after a firmware update, usually the first thing I recommend is a factory reset. Sometimes old settings can cause issues or not update properly. Have you tried this?
