gfs10's avatar
gfs10
Follower
Jan 15, 2021
RAX 120 problem communicating with Samsung 5g phone
I have a RAX120  running wpa2. the router communicates with all my devices, (even though i have found the range is really bad.) except one. if i connect my phone to the 5ghz. it connects but apps do no want to launch and the web browser comunication is hit and miss. if i connect to the 5ghz guest i have no problem and the speed is much better
i have turned off the wifi 6 capability as that was causing other problems
anyone have any ideas
1 Reply
  • As you have 2 posts and seem to have an issue with both AX, WiFi range and devices I wire up a pc or Mac and download the latest update from the support page.
    Do a manual update over the top, then reset using the rear pin hole method.
    Set the router up as new, do not use a saved config profile.
    Test.
