tadswana
Oct 26, 2020Guide
RAX 120 Router Firmware Version V1.0.2.136 Connectivity
Hi all,
Been searching through this forum and been onto tech support, it looks like a common issue. My experience has been Wifi devices losing internet (but staying connected), however ethernet devices are fine. 26 devices attached (nothing crazy) with 100Mbps internet.
It seems to start with IOS Wifi6 (Iphone 11) and then spreads to all devices, have tried multiple combinations of QOS/AX/smartconnect, 30/30/30 reset, etc.
The only thing I haven't tried yet is a manual FW update to latest V1.0.2.136 again. Shouldn't be this hard...
Thanks for the update, fingers crossed it's ok now.
- NewfiedroolVirtuoso
Try not to do 30.30.30, this is not needed with modern routers and could do more harm than good.
please try this, reset router so all settings are default, reinstall .136 over the top. Do not interrupt the install and do not use a saved config.
then perform another factory reset and then set the router up as new.
do not use HT160 in the WiFi settings, if you are this can cause devices to drop.
- tadswanaGuide
Newfiedrool wrote:Try not to do 30.30.30, this is not needed with modern routers and could do more harm than good.
Thankyou for the response, the 30.30.30 was recommended by tech support, however I found it didn't do anything!
I reinstalled .136 over the top manually, and then did a factory reset and setup as new (with smart connect on) with combined 2.4/5Ghz networks, it seems stable however will monitor over the next 24h and report outcome.
Thanks again.
- try 1.0.1.136, seems this 2nd latest version works ok. At least I can keep it running for 1 week and not get disconnect.
