tgandy2008's avatar
tgandy2008
Follower
Oct 31, 2022
RAX 120
I am using a jetpack from Verizon and need to back feed my LAN. Will the USB ports on this router work to back feed my service into it??
  • michaelkenward's avatar
    michaelkenward
    What does that mean?
    The USB ports on a router are there for storage devices and printers. Nothing else is going to work.
  • plemans's avatar
    No, you can't connect the jetpack to the RAX120's usb port and expect to provide it ethernet.
    If you search the verizon jetpack forum, many members have tired to connect their jetpacks to a router without success.
    If you're needing something like this done, I'd check with verizon about upgrading your jetpack to a different model that supports ethernet
