dglsmcd_USMC
Aug 05, 2020Luminary
RAX 200 Firmware Update 1.0.2.98
New firmware for the RAX 200 is available here:
https://kb.netgear.com/000062168/RAX200-Firmware-Version-1-0-2-98
New Features and Enhancements:
- Supports the NETGEAR automatic time zone detection algorithm
Bug Fixes:
- Fixes security issues
- Fixes the email notification issue
- Improves the system stability
- Christian_RNETGEAR Employee Retired
- SSgt93TutorSemper Fidelis!
- hellow0rldAspirant
I updated to this firmware and now my wifi is giving me incorrect wifi password errors. I did not change the wifi password and confirm it is correct in the router's settings menu. I'm also getting intermittent dropped internet connection as well with the new firmware update.
Had to switch back to my old Nighthawk X8 and it works fine without issues. Please help.
- Ever since I updated to this firmware the Nighthawk app will not detect my router. It states “Router not supported.” I can connect with Anywhere Access using my WiFi. Also, I can’t access the router set-up page from any device. Nothing works. The router itself is working fine. Any help would be appreciated.
- dglsmcd_USMCLuminary
RAX 200 Firmware Update 1.0.2.98 has since been removed from the NG download page-the current download is the previous firmware 1.0.2.88 which I would recommend installing to help out in your situation-make sure to do a hard reset and reconfigure from scratch-do not use any saved configurations.
http://www.downloads.netgear.com/files/GDC/RAX200/RAX200-V1.0.2.88_1.0.50.zip
Currently NG has restored access to firmware version 1.0.2.98 for the RAX 200. Will test this "new" version to see if there are any fixes/improvements
