JNollett
Jan 01, 2021Tutor
RAX 200 Power Supply
Hi
Does anyone know where I can buy a replacement PSU for the UK version of the RAX200?
Thanks
netgear doesn't sell replacement power supplies. I usually get them off amazon/ebay.
You just make sure they have the same output voltage, polarity. The amperage can be more but I wouldn't go less.
JNollett wrote:
Hi
Thanks
eBay and Amazon would be a good start. I have had success there.
Netgear uses the same adaptors for most devices, so look for something that, as plemans says, has the right specifications. (See the label on the device itself.)
- JNollettTutorHi, I’ve looked on both Amazon & eBay, but this has a completely different adapter end to all other adapters. Any other ideas?
I have no idea what you looked for.
The specifications in the manual say "All regions (output): 19V/3.16 ADC output". I found this in a few seconds:
19V 3.42A 65W Universal Laptop Power Supply with 5.5 X: Amazon.co.uk: Electronics
After a few more seconds, I found this one which even claims to be compatible with your device:
T POWER 19V Ac Dc Adapter Charger Compatible with for: Amazon.co.uk: Electronics
I suspect that there are dozens more where they came from.
