scott2003lhs's avatar
May 11, 2020
RAX 40 5ghz useless
I got this router in December. The last few months I did a full factory restore on it twice. No matter what 5Ghz channel I select device won’t stay connected. I used WiFi Analyzerr to find the best channels etc. The router is becoming a pricey paperweight. Wired and 2.4Ghz work fine. I have heard some people say the firmware is to blame, but it has not been updated in ages. Can anyone tell me a stable firmware to try, or even a beta one? I am working from home and 2.4Ghz is kind of slow... thanks!
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello scott200lhs,
    Welcome to the community! May you try disabling AX to see if there any improvements.
    Christian
    • scott2003lhs's avatar
      scott2003lhs
      Star
      Hey. I have done that. Now my only device that won’t connect is an Acer Predator laptop. iPhone stayed connected all day but I had to roll back to the last firmware. I’m freaking annoyed. I’m assuming my laptop is the issue now. On newest firmware iPhone couldn’t stay on. It wasn’t given an IP address from router. Now the acer does that instead
        Christian_R
        Hi scottt2203lhs,
        I would check to see if your laptop is due for a WiFi adapter update.
        Christian
