martinb0820
Apr 15, 2020Guide
RAX 75 : Problems with 5 GHz - two issues
I have an RAX 75, set up to use Smart Connect.
1. Devices are constantly flipping back and forth between 2.4 and 5 GHz. Most of these devices are completely stationary (TVs, music streamer, etc.), and relatively close to the router (the router is almost directly over some of the devices, on the second floor).
I've tried using various channels, including DFS. Using DFS channels, a couple of devices switched from 2.4 to 5 (but reverted back to 2.4), probably due to the higher power output.
The only reliable 5 GHz connection is a Samsung S-10. Every other device flops back and forth (and the S-10 moves around more than any other device, including outside the house...)
I guess I can try turning off Smart Connect and using two different SSIDs, but it would be nice if the feature worked. Is there anything I can try?
2. I'm still trying to pin this one down, but it appears that sometimes devices on 5 GHz can't see devices on 2.4 GHz. For example, one laptop was able to see a music streamer (SSH, ping, etc. were OK) while both were on 2.4. The laptop switched to 5 and completely lost communication with the streamer. During this time, I tried from two other laptops on 2.4, and it communicated with the streamer with no problems.
Sometimes, however, communication from 5 to 2.4 works.
Guest Network isn't enabled, but I did enable the option to allow guests to see each other. It shouldn't matter, but I read somewhere on this board that it might help (it didn't).
So I turned off Smart Connect, gave 5 GHz a new SSID and logged the devices that should be on 5 GHz into the new SSID. (Some of the devices had never been steered to 5 GHz by Smart Connect.) That took care of issue #1, and the network seems to be gererally working better as well.
WRT issue #2, it's difficult to prove a negative, but the streamer worked without problems for an extened period of time, last night, so that issue may now be resolved. Time will tell...
- Christian_RNETGEAR Employee Retired
Hi martinb0820,
I would recommend getting in contact with our support team using the link below.
https://www.netgear.com/support/default.aspx
Christian
