raymon_lee's avatar
raymon_lee
RAX-75 QsS problems
I have 1GB Wan Line.
Computer Lan port connect to router lan port.
When I set the Qos On. When I applied. I using the  Ookla speed test to test it will be 948.54 download speed.
When I off my computer after a day to test it is 345.55Mbps. And I goto setup to update again of Qos On/Off again is back to normal.
If I off Qos. The speed test is every time is stable at 545Mbps.
Why and how to fix this problem.
Thank you
  • 1. QoS isn't recommended at speeds >250mbps.
    2. Turn off the qos and reboot. If you're speeds don't get back to >900mbps, then factory reset and reinstall the router. Qos settings have been known to be retained and can slow your speeds.
    3. what modem are you using?
    4. Firmware you're on?
    • raymon_lee's avatar
      raymon_lee
      I follow up your suggetion is working. (factory reset and reinstall the router)
      Modem is Hauwei.
      Firmware is  Version V1.0.2.76_1.0.35
      But I don't know why the function is buld in. But can't using after set it. Is BUG ?
      And other is sesecurity Block Sites problems.
      I set any web site block. But not working.
      • plemans's avatar
        Guru
        Modem is Hauwei.-----which model?
        But I don't know why the function is buld in. But can't using after set it. Is BUG ?-------which function? be specific .
        I set any web site block. But not working. -------how are you doing this? again be specific. I'm not there to see what you're doing.
