sewsable
Sep 16, 2020Star
RAX 80 not giving clean wifi when restarted using on/off button
Ok, we've had to start turning the router off at night in order to get eldest teen to go to bed and sleep and we've noticed that every few days when it gets turned back on (using the on/off switch) that the wi-fi is not running smoothly or quickly. Websites take ages to load and You Tube gets stuck and has to be reloaded. It happens to every device connected and usually a hard reboot with unplugging the power supply fixes it, however this shouldn't be happening. It's still under warranty, but I want to check if there's a fix that doesn't involve having to set up a new router as that's a pain in the rear.
- Christian_RNETGEAR Employee Retired
Hi sewsable,
Does the issue occur only when the router is turned back and if so, for how long?
Christian
Hi Christian
It happens when the on/off button is used to switch it on in the mornings and will continue until I remove the power supply for 30 seconds and then put that back in. I tried yesterday to see if it would recover if given time, but I was still having issues last night and this morning when we turned it back on those issues were still in play.
Rachelle
Hi Rachelle,
I would suggest performing a factory reset on the RAX80 and running through the setup assistant again. You may also try to contact our support team using the link below if your issue persists.
https://www.netgear.com/support/default.aspx
Christian
