BillyBinhSVT
Oct 05, 2021Follower
RAX120 5ghz problem
WIFI 5ghz see & can not SYNC
it is FIRMWARE problem
FW: & bug
1.0.1.128= work ok ( direct JUMP update to 1.2.2.24= 5ghs wifi FAIL)
Update è 1.2.2.24= Fail 5Ghz wifi (no sync)
Downgrade è 1.0.1.136 #1 = Fail 5Ghz wifi (no sync)
Update è 1.0.1.136 # 2= work ok 5ghz WIFI=ok
Update è 1.2.0.16 = Fail 5Ghz wifi (no sync) è no see 5ghz signal
Update è 1.2.2.24= Fail 5Ghz wifi (no sync) è no see 5ghz signal
------ now have to fix again ---
Downgrade è 1.0.1.136 #2 = no display during downgrade !!
So just wait for 10 minutes à do not INTERUPT -> do nothing -> WAIT ONLY
Now work wifi kitchen-5Ghz == login OK
1 Reply
Has a factory reset and setup from scratch been performed since last update?
