todd1010's avatar
todd1010
Apprentice
Apr 01, 2022
RAX120 assign static IP's to some of my devices?
I have Xfinity internet and I'm pretty capable but before I dig in I want to make sure I'm doing this right.
I want to assign some static ip's to some of my devices so I can do some controlling via IP with a programmable remote control for my home theater.
Couple questions:
1) Before I start I understand I should use IP's "outside of the DHCP range correct? If this is true, where do I find this DHCP range?
2) Before I start I've got a list of all of my devices information I'll need but where do I find all of the DNS, etc so I can input this information into my devices settings.
3) Related to question number 1, I've also read that "some" devices don't like being outside of the DHCP range, if I find a device that doesn't like this I've read that I should us IP addresses in the upper limit of my DHCP range to help with any new devices that I may setup in the future.
Any other helpful hints you can help me with please post away.
  • FURRYe38's avatar
    Couple questions:
    Under Advanced Tab/Setup/Lan Setup.
    To have static IPs work right that are set ON devices, first change the default DHCP IP address pool range to 192.168.1.100 thru .200. Then you can setup and configure static IP address ON devices on ether side of this pool. Anything with in the pool gets Dynamically assigned or IP Address Reservations are meant for inside this pool.
    • todd1010's avatar
      todd1010
      Apprentice
      Thanks for the useful information on setting the DHCP range to 100-200 which I did.
      I then started setting my static IP addresses at 201 and up.
      • todd1010's avatar
        todd1010
        Apprentice
        Also,
        Do you guys recommend doing DHCP Reservations for devices that you can't setup a static IP?
        The devices I'm talking about are things like my Sonos speakers, Ecobee Thermostat, MyQ Garage Door Opener, Levition Light switch, etc? Basically things that will be just sitting on the internet the entire time without much needing to change stuff on it.
