BobSwitz
Aug 15, 2021Aspirant
RAX120 Configuration and firmware
Greetings,
Does anyone have firmware ver. and configuration settings that work well all I want is screaming fast wifi with no buffering?
I have spectrum with 400Mbps.
I just purchased the RAX120 since I've been using Netgear routers for may years.
Well I have been very disappointed in the performance, I loved the initial speeds on Wifi but my devices keep disconnecting, apparently a common issue.
My initial wifi speeds were in the 450 - 460Mbps range, but streaming on wifi I get the buffering and no connection symptoms.
Could only reach a chat support person who had me make configuration changes to the router, reboot Cable modem and Router which made my speed drop down to 24Mbps.
I backed out some of the changes until I got back to 450 - 460Mbps range, but still get buffering etc.
I'm on the verge of returning.
I would truly appreciate any help.
Bob
- thehypnootoadLuminary
Drop the 5ghz down to hx80 from 160 do router reboot from button see how it goes.
HT 80 from HT 160
- BobSwitzAspirant
Thank you for the suggestion I will try it this weekend when I get home.
I also noticed every morning when I check the log it says up time for the router is anywhere from 1hour to 3.x hours I don't believe it should be going down every night.
Thanks again.
Bob
- thehypnootoadLuminaryWhats the log saying so can tell if its not a isp drop from modem or a router reboot. Usual questions & answers.
Are you on the latest firmware? If so how did you upgrade did you try a pin hole reset ?
