pjd813's avatar
pjd813
Guide
Jun 27, 2022
RAX120 does not keep WAP2~WPA3 Personal settings
When I try to set WPA to anything other than WPA3 the setting always goes back to WPA3. I have an 8 year old Logitech Universal Remote that uses WiFi and I believe the WPA setting may be causing issues with connectivity. Any suggestions?
  • Thanks for the question about browser vs. App. I was using Safari thru iPadOS so I tried the Nighthawk app and the WPA2+WPA3 setting now looks like it is “sticking”. That also seems to have fixed the Logitech connectivity issue.
  • plemans's avatar
    Are you doing it through the browser?
    through the app?
    Have you tried a different pc and/or browser?
    • pjd813's avatar
      pjd813
      Guide
      • plemans's avatar
        Glad you got it working!
        might mark it solved so others aren't still trying to fix your issue 🙂
