speedi1's avatar
speedi1
Tutor
Jan 16, 2023
RAX120 Ethernet ports max 130Mbps?
I have an issue that I just started experiencing with my RAX120 -- the Ethernet ports will not longer go about 130Mbps when I doing a speedtest through Windows 11. The wireless 5GHz speedtest still goes about 850Mbps on my phone. I have changed cables and looked at my configurations.. nothing has changed. I'm assuming my ports or something could be toast?
  • plemans's avatar
    One thing to check is if the test is displaying it in MBps (megabytes per second) or mbps (megabits per second).
    Because 125 MBps is 1000mbps.
    I've seen it displayed with the megabytes before and throw people off thinking their device was running slow when its just how the speedtest is displaying it on certain devices.
    • speedi1's avatar
      speedi1
      Tutor
      Thanks.. you definitely made me double-check. It's Mbps, not MB/s.
      • plemans's avatar
        have you tried a different wired device?
        And/or website and browser?
