duckware
Feb 03, 2019Prodigy
RAX120 is dead -- does NOT fully support 802.11ax
Read the fine print.
https://www.netgear.com/images/datasheet/networking/wifirouter/RAX120.pdf
"This router does not support some of the mandatory features ratified in Draft 3.0 of IEEE 8...
IrvSp
Feb 03, 2019Master
Well, it seems NG has sort of covered that with the prior statement:
Maximum wireless signal rate derived from IEEE 802.11 specifications. Actual data throughput and wireless coverage will vary and may be lowered by network and environmentalconditions, including network traffic volume and building construction. NETGEAR makes no representations or warranties about this product's compatibility with future standards. This router does not support some of the mandatory features ratified in Draft 3.0 of IEEE 802.11AX specification, such as Uplink OFDMA, Target Wake Time, and BSS Coloring.
Since this will not really be 'formalized until 3rd quarter this year, buying it now 'trusts' NG to update it as more Draft approvals (#3 what the last approved in July I think?) are made, and MAKE the required changes.
Wonder if this is the reason for the 'Beta' program that runs 90 days (https://www.netgear.com/landings/premier/)? Put in place just in case the UNIT has to be replaced to handle the newer Draft?
- microchip8Feb 03, 2019Master
This model is still based on a draft. These features may be added later (if possible with firmware release)
- schumakuFeb 03, 2019Guru - Experienced User
Check the timeline of the releases Status of Project IEEE 802.11ax High Efficiency (HE) Wireless LAN Task Group - ways off from final.
I don't think ASUS does it any better with their AX88U model
- IrvSpFeb 03, 2019Master
That is always the gamble with early adoptor's. Both the maker and buyer... you 'hope' the chipset/planar will support any new draft changes or requirements. If they do, great. If they don't, what to do? Chipset problem, well does the vendor of the chipset even have a replacement and drivers/code for the final released 802.11 version, and if so, how long to get it? Now how to 'push' that out to purchased h/w by end-users. Even if there is a required code change, how long to get that 'bug free' after the final release.
On top of that, this is more tricky, 3 parts actually, biggest the chipset maker if code/drivers are needed, then the router vendor incorporating that into the router firmware, and lastly, a client device with the same problem set if bought pre-final release.
I think I'll wait, but not everyone will/does.
They push out improved models (with better conforming chipsets) on the draft by calling it v2 or v3. I have NG switches that are at version v4
- duckwareFeb 04, 2019Prodigy
It is not right for Netgear to place "This router does not support..." in the fine print of a spec sheet that virtually no one will see.
