Kreckon's avatar
Kreckon
RAX120 MMS Messages Not Coming Through
Got a problem and can't seem to figure it out after two weeks of researching and testing.
New RAX120 router, since being installed, none of the cell phones that connect via my Wi-Fi can received MMS image texts. Doesn't matter the carrier or phone model (iPhone or Android), about a dozen cell phones in total testing via family and friends, all the same results. If the Wi-Fi is disabled on the phone, and connects to cellular network, the images instantly come in. Previous non-netgear router, never had an issue, started as soon as new RAX120 was installed. SMS text worked fine, appears to only affect MMS images. It shows up on cell phone as attempting to download, then eventually times out. I do not have neighbors close enough where their wi-fi network/channels would interfere with mine. Do have another router for security system using channel 11 only. Needless to say, wife and kids are not happy.
Currently using channel 8 channel 153 for RAX120. Both channels, same results.
Troubleshooting steps already taken:
  1. Due to other hardware issues, Netgear replaced router, both routers same issue
  2. Tried firmware version 64, 78, 84, and 100, no changes
    1. Did router reset with each firmware change
  3. Disabled AX & 20/40 Coexistence options
  4. Did factory reset, left default settings, no change
  5. Only connected cell phones after a reset, no other Wi-Fi devices in case something connected was interfering
Appears to be numerous forums and discussions about this problem, but no one seemed to have a solution on the ones I found. Hoping someone ran into this before and found the problem.
Much appreciated.
  • plemans's avatar
    What modem are you using? make and model number help.
    Are you using anytime of vpn service?
    have you tried Disabling SIP ALG?
    Some voice/video communication applications do not work well with the SIP ALG. Enabling this option to turn off the SIP ALG may help your voice/video applications to create/accept a call through the router.
    • Kreckon's avatar
      Kreckon
      Thank you Plemans for the reply and recommendation. Tried disabling SIP ALG, as I had not tried that, but unfortunately did not work. Rebooted router after change, just in case.
      As far as the modem, it is a Hitron coda-4589, currently in bridge mode. Didn’t look at the modem as a possible problem, as previous router worked fine with the same modem. Only change was installing the new RAX120.
      Haven’t used or configured any VPN service since installation of new router. All VPN settings are currently default.
      Thanks again for the recommendation. Willing to try anytime as wife is pushing me to revert back to old router, but really would prefer to stay with this one.
      • plemans's avatar
        Something to try?
        Put the Hiltron back on router mode, disable the wifi on it, and put the rax in ap mode.
