afhvengeance's avatar
afhvengeance
RAX120 No 2.4ghz
Arrived home today and noticed a few connected devices flashing red lights at me. After a little research, realized the router is no longer broadcasting the 2.4ghz band. 5ghz is still up and working. The 2.4 ghz light is on and blinking on the unit. I have tried simply rebooting, updating firmware to the latest (1.2.9.52), factory reset, nothing has made it come back. The unit is definitely outside of the warranty period... Any other things to try before I start shopping?
  • michaelkenward's avatar
    michaelkenward
    Is it just some devices that lose the wifi?
    By design the RAX120 uses Smart Connect and doesn't have separate SSIDs for 2.4 GHz and 5 GHz, so it isn't always easy to work out if they are both broadcasting.
    • afhvengeance's avatar
      afhvengeance
      Smart connect isn't on, and it has always broadcasted two different SSIDs, the network name, then the network name-5G. It completely stopped broadcasting the former, meaning devices that could see it previously and connect to it, can no longer do so. If I go to the attached devices page, all of the connected devices are either wired or on the 5G band.
        michaelkenward
        OK. It was important to fill that missing gap in the details you provided.
        Another missing detail, have you also checked that the RAX120 is set the broadcast the 2.4 GHz SSID? That is also something that you can toggle in the GUI.
        You said earlier that you had reset the router. Did you check that you had restored the earlier settings? Is Smart Connect still off?
  • FURRYe38's avatar
    Try a 30-30-30 reset on the router.
    https://www.lifewire.com/hard-reset-rule-for-routers-3971318
    If this fails, one could just disable the radio fully with in the router and install a 2.4Ghz wireless AP wired to the RAX router so you could continue using the RAX other working features.
