humblealpha's avatar
humblealpha
Initiate
Aug 14, 2021
RAX120 question about wan/multigig
Hello, I have just upgraded my broadband speed to 1GB+ with expected speeds around 1150mb/s.    I was looking into getting a router that would support speeds of over 1gb.    I saw that the RAX120...
  • plemans's avatar
    Aug 14, 2021
    Problem with a lot of these devices are only having a single 2.5/5g port on them.
    But most that have that option, also support wan/lan port aggregation.
    so you can either use it with wan port aggregation to get the speed gig+ and then connect devices to the 2.5g port.
    Or you can use the 2.5g for the wan port and the lan aggregation for the computer.
