rax120_rax80
Mar 08, 2020Apprentice
RAX120 Router Random Disconnects
Hey everyone, I know that I'm not the only one with problems on the Nighthawk WiFi 6 devices, but thought I'd post my most recent headache. My hardware consists of a Motorola MB8600 DOCS 3.1 modem w/...
Killhippie
Mar 19, 2020Prodigy
You could try to restore the important settings over SSH/telnet.
rax120_rax80
Mar 19, 2020Apprentice
Yeah, that's what I was asking. What files store this information? I can write a script or just VI once I'm in and paste the settings in the config files.
- KillhippieMar 19, 2020Prodigy
Something along these lines maybe?
Options: -h this help msg -v Print version/perform consistency check -b Backup mode - save for restore to same router (default) -m Migration mode - transfer settings to another router -i inifile Specify custom nvram variable ini file -clk Include clkfreq/overclock setting (Backup mode only) -nojffs Skip backup of jffs storage -nouser Skip execution of user exit script - TopologyMar 20, 2020Virtuoso
Rax120_rax80, having the ability to export, edit, and import some (or all) of the router’s settings is an excellent suggestion. That capability would not only facilitate restoring a router to a workable state following a factory reset, but would also assist when upgrading from one Netgear router to another. I recommend that you post the suggestion to the Idea Exchange For Home.
P.S.: Has your RAX120 been running well, since performing the factory reset followed by the manual entry of the router's settings?
