gixser11
Aug 22, 2019Follower
RAX120 Slow Speed
I have RAX120 with gigabit internet. Previously I was getting up to 700MB speed over WIFI with the router. Not sure what changed, but I am not getting 20MB. Hardwired I am at 800MB. The only change...
Aug 23, 2019Guru - Experienced User
The RAX devices firmware is still in close to beta form if you ask me. It might have updated to a newer version with issues. A couple things you could check or try.
1. Do you have AX enabled? Try disabling it and seeing if it helps.
2. What firmware ARE you on?
3. With these newer devices, its good to update over a hardwired connection and to reset it afterward. If it auto-updated and therefore didn't reset, I'd start there. You could try reloading the current firmware manually and doing a reset in case it was an error during the update.
4. Last ditch effort would be to downgrade the firmware a version to see if that'd help. maybe if it updated to a newer firmware, there was a problem with the firmware.
here's the support site with firmware and manuals.
https://www.netgear.com/support/product/RAX120.aspx
