gixser11
Aug 22, 2019Follower
RAX120 Slow Speed
I have RAX120 with gigabit internet. Previously I was getting up to 700MB speed over WIFI with the router. Not sure what changed, but I am not getting 20MB. Hardwired I am at 800MB. The only change...
jaredaka007
Nov 07, 2019Aspirant
I have the same router with 1 gig down and 40 up. I noticed that if WMM is enabled in QoS my wired speads slow to about 250 mg but my wireless is like 750 mg on 5g. If you disable WMM for both channels my speed wired goes up to about 932 mg and wireless goes to 17 mg. I have worked with support for about 4 hours and swapped routers still same problem IMO I think there is a Firmware issue. Until they can resolve this with a fix i would suggest playing with the above setting...
