gixser11
Aug 22, 2019Follower
RAX120 Slow Speed
I have RAX120 with gigabit internet. Previously I was getting up to 700MB speed over WIFI with the router. Not sure what changed, but I am not getting 20MB. Hardwired I am at 800MB. The only change...
avtella
Nov 07, 2019Prodigy
Unfortunately disabling WMM on practically any router would reduce wireless to effectively G standards ie 54 Mbps link rate so something like 30-40 or so Mbps in real world throughput. Is this affecting only WAN(Internet) or LAN file transfer tests as well?
Looks like a firmware issue, I personally haven’t run into this fortunately in my testing in LAN tests. I can’t do a WAN side test as I only get 300 Mbps from my ISP.
aonavy1
Nov 07, 2019Guide
I had the same issue. Try changing the 5ghz band channel to something like 100 and disable QOS. Keep AX on though
