ehmabe
Sep 28, 2020Aspirant
RAX120 Slow Speeds Wired
My ISP service is 200 mbps DL . Currnelty with the RAX120 my speeds are around 90 DL. When I bypass the router and direct to the modem I am running 226 Mbps. This happens to the firmware 122 and up.
Any ideas what I settings I need to set. When I used the Qos the speeds drop to less than 20.
are you testing wired/wireless?
Have you checked the cable? it seems like you're dropping from a gigabit connection to a 100mbps connection. You can check this by logging in and going to advanced-----show statistics.
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
If its showing that port at 100m and not gigabit, then its time to check cables/modems/ports.
