coyote3
Jul 26, 2019Guide
RAX120 spontaneously disabled wifi & router password
My RAX120's wifi and router password (including the default password "password") suddenly stopped working.
So I reset the router password (with the serial number); when I then tried restoring the router config the reset password didn't work either, so...
I reset the router password again and turned on the wifi and all seemed well. And all settings were preserved so I didn't really need to restore the router config but I tried anyway and again couldn't login so had to reset the password again. Once I did the wifi was already enabled.
So having learned that (the un-needed restore wouldn't work) I backed up and then tried to restore the brand new router config. That worked AOK, so now I have a restorable backup config.
However, I'm still concerned that somehow my RAX120 spontaneously turned off it's wifi and decided not to recognize my (or the default) password. Seems like a bug, so I fould myself irritated that I'm a week past the puny 90-day phone support period, I couldn't talk to Netgear free.
Thankfully I'm not past the 1-year Warranty yet, but I'm tempted to exercise it, particularly if this happens again.
Current f/w v1.0.0.84
- Christian_RNETGEAR Employee Retired
Hello coyote3 - Curious to know if the issue reoccurred. Feel free to update the thread with any updates.
~Christian
- coyote3Guide
Thank you kindly for asking, Christian!
The issue hasn't recurred (yet; all was well for 97 days until the first occurrance).
I will not fail to update this thread if it does recurr (both for the community, and for myself [forum threads are also useful simply for documenting one's own situation]).
Hi coyote3 - Thanks for getting back so soon! Feel free to reach out if I can be of any assistance.
~Christian
- SurfndezAspirantHaving same issue, but without moving it around. Tried a various number of configurations to see if it fixed the issue (maybe other signal sources causing problems) no luck.
Finally did a hard reset. Worked for 12+ hours, then same issue returned. Password gets wiped at router, particularly on 2.4GHz band, failed to get ip and or will not connect, and internet/no internet fluctuation often.
I'm a developer on the side, so tech savy, tried fixes on modem side as well. Not sure if this is firmware issue.
Dez
