BioRAX120's avatar
Nov 24, 2024
RAX120 SSH access
Hi all, I have a RAX120v1 with last firmware installed ( v1.2.9.52 )
I was able to enable the telnet port so I can logn into the router via telnet terminal on port 23
My question is:  being connected into the router via telnet do someone know which linux command I can use to enable the port 22 SSH connection?
I don't even know if an ssh server is active / running on the RAX120 so it's just a matter to somehow enable the firewall to let me use the SSH on port 22 or instead is not possible?
  • FURRYe38's avatar
    Most likely not possible. SSH may required special keys that are not made public for security reasons.
    • Hi and thanks for your reply.
      well, I am a beginner so I don't have experience and knowhow, but reading several article on the web I see
      someone did it on other netgear router, maybe having Dropbear SSH installed as server..?
      Do you know if this would be possible, or any other ways
      • FURRYe38's avatar
        What other NG router model was this?
        NG removed Telnet access support from most of there newer versions of FW. Though I presume one may have found alternative means to enable telnet access.
