derekcannady
Dec 23, 2021Guide
RAX120 V2 Constant Random Reboots
The router reboots frequently sometimes every 30 minutes. I have noticed that the router reboots under heavy system load of +50% on the processor. The only way I have been able to drastically lessen the issue is by turning off 2.4 Ghz WMM services. Unfortunately my 2.4 Ghz devices pay the price for that with slower throughput. I can't even view some security camera streams any longer because the bandwidth is so poor.
I first purchased this router about a month ago and have already had the unit replaced by NG once but unfortunately the replacement does the same thing. I am within the time period to return the router. I'm hesitant to purchase the RAX200 because of the same issue. I may have to try another brand after 10 years of using NG. It doesn't look like Netgear has a solution for this either- I've spent plenty of time troubleshooting with the Level 2 support folks (they spent a lot of insinuating that the power outlet was the culprit, even after trying the router on several outlets and APC backups)).
- Installed beta firmware 1.2.3.33 on it and then turn fan on in debug.htm. Just check mark it , don’t click on apply.
And bought a cool pad from amazon $10 . 4 days in a row no restart and router works perfect.
Laptop Cooling Pad,ESGAMING Laptop Cooling Stand Laptop Cooler 10-15.6 Inch 2 USB Ports 2 Fans with Blue LEDs https://a.co/d/dXVVnxw
- apakettAspirant
I would also like the beta firmware
- Serial Number: 6JY
- Modem: CM1100
- Service provider: Spectrum
Thanks,
Allan
- OnZoRAWAspirant
Could I please get the rc firmware update?
Having random reboots, mostly seems during downloading large files (sometimes multiple times during the same download).
Router: RAX120v2
Serial number: 6K0....
ISP: Ziggo
Modem type: Either a proprietary Arris or Compal
Modem is in bridge mode
- Reub4965AspirantCould I please get the beta.
Router: rax120v2
serial: 6JY
Modem: Netgear cm1000 - Giggi33Aspirant
I ask again
My serial starts with 6K0
I have the v2 model ... please send me the firmware update.
Thank you.
