atsrxL
Jul 26, 2019Aspirant
RAX120
I got my brand new Rax120 and Intel ax200 wireless Nic I've got mainly 3 issues 1. If enable AX The connection speed is 2.4g but it only transmit around 58mb/s from my Synology NAS while it's conne...
avtella
Jul 28, 2019Prodigy
I’m not sure what you mean by no AX transmission, I have 3 Intel AX200 clients and all are faster on AX mode by 10-15% vs AC mode on 5Ghz which is expected, 20% is the best I’ve seen. On 2.4 GHz on 20 MHz mode I get a 2X gain with AX over AC. That was on the .84 firmware when I tested after buying the router in April. A few reviews from various sites are also up showing gains on AX.
avtella
Jul 28, 2019Prodigy
They’re probably asking for logs because not everyone is having this issue and it might be down to certain differences in different test/use environments.
