arthurbeg
May 13, 2020Aspirant
RAX120
Just bought a brand new rax120 from bestbuy previously had the rax80 both routers seem to cap out at 300mbps when i have gig speeds. tried everything and nothing helped. are these routers just horrible or do they actually work anyone?
1. What modem is it connected to?
2. What firmware is on it?
3. Try enabling IPv6
4. something to try? If you just bought it, it probably just got a bunch of updates. Try a factory reset and run it with basically stock settings. Don't enable qos, traffic monitoring, parental controls, armor. See what speeds you get straight from the factory.
It should run gigabit.
5. Also check the website you're testing with. not all can saturate gigabit. Try speedtest.xfinity.com or dslreports.com
6. What device are you testing on? Make sure you're testing over wired connections and not wireless.
- arthurbegAspirantit’s connected to a cm1200 modem, i’ve tried to run with it’s cat5e wire, cat6 wire and cat7 wires all with the same results. wired connection is the same. wired straight from the modem gets me the speeds i need. it’s on the latest version 122 i have tried downgrading to 118 and another one i can’t remember. got those numbers straight out the box for 2 days before messing with it. i’ve ran on fast.com, speedtest.net and cox’s speedtest with the same results
- arthurbegAspirantI’ve ran the test on 4 different iphones and 3 different laptops. 3 of the iphone have ax and 1 of the laptops has ax as well
- dcincaApprentice
Try reset the router and do a fresh setup.
This is my setup:
Firmware .122
Enable AX
Enable OFDMA both 2.4ghz and 5ghz
5G channel 44
HT80 or HT160Enable MU-MIMO
QoS: Enable WMM both both 2.4ghz and 5ghz
Dont't plug anything to USB
try it to see if it works.
- arthurbegAspiranthave the exact same settings on a fresh fractory reset.After further testing i found out just about every server on speedtest was running 300mbps except for 2 out of the 20 i went through, bluespan and sprint with those i was able to see 650mbps. Got my cat8 wire helped those jump up to 700mbps then got a rgb11 wire for the router and that bumped me up to a consistent 750mbps on my iphone. Only issue is sometimes for long periods of time those speeds will drop down to 200-300 and a couple rooms get those speeds always. So i’m thinking about possibly switching to the orbi ax600
- arthurbegAspirantforgot to mention with those 2 wire upgrades all the servers that were capping out at 300mbps now cap out at 400mbps
- Tofu-GolemApprentice
I know this sounds stupid, but sometimes I have to enable QoS, reboot, disable QoS, reboot to get speeds where they should be.
(Also try the other way around if you prefer QoS on.)
I have no idea why this helps, but it has helped both on my RAX80 and my RAX120. If doing this fixes the problem with speed, this suggests to me that it could be fixed in software, but from what I can tell, Netgear's firmware teams are scrambling to deal with a lot of problems (including some scary security problems with over 70 models). If this can be fixed in the firmware, who knows when that will actually happen.
