Laggs84
Feb 11, 2026Aspirant
RAX120
I am having the exact same issue with my RAX120, I have a modem (no router) that works perfectly when connected to wan port on my router, but when I connect it to my multi gig port it stops working. Yes, I go to internet settings and set the wan port to 5G multi-gig port and I reset the router and I reset the modem several times in different time sequences and so on and so forth and i get the same thing, the internet does not work when connected to the 5G wan port. Funny thing is that I have 2 RAX120 and neither of them work when connected to the 5g multiport wan. The modem is 2.5g capable and the cable is cat6.
- coolwifiVirtuoso
Do you have the firmware updated to the latest version? You need to change the WAN port settings and power off the modem and router and finally turn on modem first and then the router. Power cycling needs to be done several times if the router wan port doesn't detect internet. The same issue happened a few times in the RAXE500 router that I had a while back.
What modem is it?
Did you try a different cable?
