Galliard_CX's avatar
Galliard_CX
RAX120V1 Intermittently power cycling?
My RAX120 that I purchased around a month ago has suddenly started to "Turn off" leaving only the power LED on (blinking). During this item, all internet service is interrupted and after about a 1-minute wait the router resolves itself and resumes function.
I've been informed that there may be a BETA Firmware that resolves this issue. Any help would be appreciated!
  • Have you done a factory reset and configure from scratch? It might help.
    • Galliard_CX's avatar
      Galliard_CX
      Yeah, that was the first thing I opted to do. I've been trying to figure this issue out for the past few days and I was informed of a BETA Firmware that may resolve the issue that I can access from this forum via Reddit just a little while ago
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What is the first 3 characters of the routers serial number please.
      Galliard_CX
      1: I rolled back and used V1.2.3.28 in hopes of that resolving the issue, it did not. Currently using 1.2.8.40
      2: Unfortunately I am not sure what "Mfr" means, the closest thing I see on the modem is "mfg" which states 06/21. The modem is provided by Spectrum and is Model Number "ET2251"
      3: Im using this cable in the 6 ft size.
      • DarrenM's avatar
        DarrenM
        Sr. NETGEAR Moderator
        Hello Galliard
        I have sent you a PM.
        DarrenM
