DrWatt
Aug 06, 2022Aspirant
RAX120v2 How to determine which device is connected to which of the numbered ethernet ports
RAX120v2 firmware version: V1.2.3.28 Windows 10 Pro version 21H2 Summary: How to find what device is connected to ethernet port 1, what device is connected to ethernet port 2, what device is con...
Aug 06, 2022Guru - Experienced User
It won't tell you device specifics but it will show the connection details under the wan port statistics.
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- DrWattAug 06, 2022Aspirant
I was hoping that it would provide either the device name or MAC address (or both) attached to each ethernet port. I suppose I will just have to manually test each cable and then apply a label.
Many Thanks for your reply.
