Ifrosty2's avatar
Ifrosty2
RAX120v2 randomly reboots/drops connection
recently purchased a NightHawk RAX120v2 as a replacement to my older nighthawk model. This model is up to date on firmware and is still dropping internet connection and rebooting itself atleast once or twice a day. Any fix for this?? All connections and software/firmware up to date and modem is fine as well.
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Using the Internet Port or Multi gig port for the connection to the modem?
    https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/New-RAX120-RAX120v2-Firmware-Version-1-2-8-40-Released/m-p/2303927/highlight/true#M32683
    • Ifrosty2's avatar
      Ifrosty2
      Firmware 1.2.8.40
      Cat 6 cables
      Fiber modem provided by isp. Not sure exact details atm, spectrum says this router is compatible with their modems.
      Using internet port.
      • michaelkenward's avatar
        michaelkenward
        What is that modem?
        Spectrum has supplied many different modems over the years. Some of them are modem/routers which complicates things.
        There should be a label on yours to tell you what you have.
        What does "Using internet port" mean?
        You plugged the modem into the WAN port on your RAX120v2?
