mpe2903's avatar
mpe2903
RAX15 AX1800 Internet speed only peaks at 300mbps
Hi,
I have a similar issue as described here:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX15-AX1800-bottlenecks-my-internet-speed-1gb-from-modem-drops/m-p/1973866#M12695
This did not solve my problem however.
  • I removed all the settings as described like QoS, etc
  • Factory Reset
  • Rolled back firmware and then restored the latest.
I have a gig connection but I can never get more than 300.  Right now i'm at 100.
I think at this point I was sold a lemon but i'm hoping theres a resolution that doesn't include me buying a new router.
Thanks.
  • plemans's avatar
    You have an RAX15.
    What firmware is on it?
    What modem/gateway are you connected to?
    How are you testing? Wired? wireless?
    What website are you testing on?
    • mpe2903's avatar
      mpe2903
      My Router: Nighthawk RAX15
      Firmware Version V1.0.2.64_2.0.42
      Arris SB8200 modem.  980mbps down direct connection.
      wired and wireless with multiple devices
      xfinity speed test, speedtest.net
      • plemans's avatar
        What port on the SB8200 are you connected to?
        Make sure its port 1 and nothing else is in port 2.
        have you tried a different cable between modem/router?
        After you reset the RAX15, did you ever speedtest it with it running in default configuration? without changing anything in settings?
        I'd try this.
