Retired_Member
Mar 26, 2021RAX20 - unable to setup router as wireless repeater
I bought an RAX20 AX1800 Wifi-6 router. I am unable to configure the router as a wifi repeater. I have an existing WiFi router and want to extend it wirelessly using this router. However, the only setting I could find was for the 'Wireless AP mode' which requires connecting a LAN cable.
I would really appreciate any help.
You're correct. It doesn't have a wireless repeater mode.
No where in its specifications does it advertise as such.
You could look into returning it and getting a wireless extender or you could look at finding a way to hardwire it in and use it as an access point
1 Reply
