microsvc2's avatar
Jan 26, 2022
RAX20 connecting to internal server
I have a web server with an ssl certificate located inside my network.  From outside the network, I can connect to it with the HTTPS:// url.  From inside the network, I cannot connect to it at all (https or http), actually I get the username and password prompt for the router instead.
What should I do in the router to fix this anomoly?
Bob
  • FURRYe38's avatar
    Might set up a specific port foward configuration to this web server if your trying to access it from the WAN side.
    • microsvc2's avatar
      microsvc2
      Tutor
      It connects thru the router from outside the network (i.e. at my work office) but I cannot connect to it from inside my network.  When I put the url in the browser, I get a login prompt.  If I click sign in, it displays the router's home page.
