KissedAngel
Aug 03, 2020Aspirant
Rax20 "keeps starting up"
Hello, so set up of this router went smoothly. Then about two hours later it just stopped working. Now power led is an amber colour, which the manual say is the router starting up, but it's been half an hour and nothings changed. Nothing happens when I press the reset button, and my father took away the unit from the night hawk app so I'm at a loss of what to do.
- KissedAngelAspirantThe full model name is ax1800 rax20
- Christian_RNETGEAR Employee Retired
Hello KissedAngel,
If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/default.aspx
Christian
