debrasheila
Dec 09, 2022Aspirant
rax20
A site is being blocked on this computer but not on my other one. I am using Windows 10. model ax1800. I reset the router but that did not help.
Dec 09, 2022Guru - Experienced User
You have the RAX20?
What modem/gateway is it connected to?
What firmware is on it?
What site is getting blocked?
Does it say whats blocking it?
Are you using Armor or parental controls?
debrasheila
Dec 10, 2022Aspirant
ARRIS TM1602 MODEM
Optimum ISP
blocked site: epicmychart.optum.com
Error message: DNS_PROBE_FINISHED_NXDOMAIN
no Armor or parental controls
Do not know about firmware
- plemansDec 11, 2022Guru - Experienced User
Do you have ipv6 enabled?
- debrasheilaDec 11, 2022Aspirant
I do not know what that is
