debrasheila
Dec 09, 2022Aspirant
rax20
A site is being blocked on this computer but not on my other one. I am using Windows 10. model ax1800. I reset the router but that did not help.
Dec 11, 2022Guru - Experienced User
debrasheila
Dec 11, 2022Aspirant
I entered the user name and pw. Message said connection not private and would not allow me to go further
- plemansDec 11, 2022Guru - Experienced User
What is saying not private? (a screen snip helps)
- debrasheilaDec 11, 2022Aspirant
See link to error message.
Is it OK that I am using the same computer that has the problem?
Debra
- plemansDec 12, 2022Guru - Experienced User
1. a screen snip is better.
2. that a message coming from windows/your browser. Its not the router blocking it. Try using a different browser or pc/laptop
