debrasheila
Dec 09, 2022Aspirant
rax20
A site is being blocked on this computer but not on my other one. I am using Windows 10. model ax1800. I reset the router but that did not help.
michaelkenward
Dec 12, 2022Guru - Experienced User
If both computers are on the same network connected through a single router, then it isn't likely that the router is doing this.
They will both see the same settings on the router. A more likely culprit is the Windows PC that is blocking your access.
- debrasheilaDec 12, 2022Aspirant
Thanks.
The problem is the same using a different browser.
Do you have any suggestions where to look? I am running Windows 10. Security software is Windows Defender and Norton 360.
- michaelkenwardDec 12, 2022Guru - Experienced User
debrasheila wrote:Security software is Windows Defender and Norton 360.Both PCs?
Do you have any suggestions where to look? I am running Windows 10.You could try running the Windows Network Troubleshooter.
