wanijsena
Apr 10, 2023Follower
RAX200 - WiFi 5ghz-2 disappears when setting 4800mbps
Hello, setting up my new RAX200 i noticed that 5GHz-1 is set to 4800mbps and 5GHz-2 is only set to 2400mbps. I upped the second channel to 4800mbps and it has disappeared completely? WiFi analyzer...
Kitsap
Apr 11, 2023Master
wanijsena wrote:Hello, setting up my new RAX200 i noticed that 5GHz-1 is set to 4800mbps and 5GHz-2 is only set to 2400mbps.
I upped the second channel to 4800mbps and it has disappeared completely? WiFi analyzer no longer shows it. Is this normal? I tried setting 5GHz-1 to 2400mbps thinking only one could be set to 4800mbps but 5GHz-2 is still not there, only setting it back to 2400mbps seems to bring it back? Normal? Cheers.
Educational material located here: https://www.duckware.com/tech/wifi-in-the-us.html#tribandhype
See appendix N
