Den7
Jul 06, 2023Tutor
Rax200 Different SSID for each channel, Upgrade router with channel 6,
Hi, I would like to replace my (RAX200-(2.4, 5-1, 5-2 bands each setup with different SSID)). I want to keep the same 3 unique SSID and passwords when i upgrade. QUESTION; New devices seem to ...
Jul 06, 2023Guru - Experienced User
Depends on router. The (6) either means AX mode which is WiFi6 or the (6) means the frequency 6Ghz thus WiFi 6E.
If you don't use Smart Connect then 2.4, 5 and 6Ghz will have separate SSID configurations.
