Den7
Jul 06, 2023Tutor
Rax200 Different SSID for each channel, Upgrade router with channel 6,
Hi, I would like to replace my (RAX200-(2.4, 5-1, 5-2 bands each setup with different SSID)). I want to keep the same 3 unique SSID and passwords when i upgrade. QUESTION; New devices seem to ...
Jul 07, 2023Guru - Experienced User
The RAX200 is a pretty rock solid and fast router.
May I ask why you're looking to upgrade?
Do you have 6ghz devices you're looking to support?
- Den7Jul 07, 2023Tutor
When i reboot the modem, then router RAX200 per procedure sometimes all my wireless devices do not reconnect. So i have to got through serveral reboots of the RAX200.
I did do a factory reset the other day to start fresh, will see what happens.
Just as maintance i reboot modem and router, several times a year.
Thank you
- plemansJul 07, 2023Guru - Experienced User
when you run into that issues, instead of factory resetting, try changing what channel the 2.4ghz is on. maybe interference is causing issues.
