FluidFactors018
Apr 15, 2023Guide
RAX200 in AP mode inaccessible, had to reset
Does AP mode truly work on the RAX200? I put mine into AP mode (keeping defaults), and it immediately stopped working for all intents and purposes. Wired clients could not get an IP address (even though the WAN port was connected to the main router providing DCHP), and although the RAX's wireless networks were still visible, I could no longer connect to any of them from any client (they'd struggle and eventually time out). In addition, no amount of manual IP setting would allow wired clients to see the RAX. When I looked at the other router (which was providing DHCP and the internet connection for the AP mode RAX200), I could see the RAX would be assigned an IP address for a little while, and then disappear from the network. After an hour of flailing with it, I finally gave up and hard-reset the RAX, as I couldn't connect no matter what I did. It's working again (_not_ in AP mode), but I'm wondering what could have gone wrong. Any ideas from those who have done this?
For those who are wondering why in the world I would put the RAX200 into AP mode, I'm trying to avoid a double-NAT situation. My home is wired in a troublesome way, and the best location for a Wifi router is far from where the internet comes in (the latter being well-connected to wired jacks throughout the house). As a result, I have a separate router where the internet enters the house (providing a firewall and acting as a switch for various outlets/devices), and it provides a WAN connection via MoCA to the centrally-located RAX200, which is my main wireless router. Unfortunately, with there is no way to connect wired clients to the RAX, which is why I have two routers, and with the double-NAT setup, a couple of my devices don't work. Is there another way to make this setup work without the complexity?
Is this what you did?
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
When you did that, did you also restart your network in the right order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
For those who are wondering why in the world I would put the RAX200 into AP mode, I'm trying to avoid a double-NAT situation. My home is wired in a troublesome way, and the best location for a Wifi router is far from where the internet comes in (the latter being well-connected to wired jacks throughout the house).Perhaps this is the source of your problem.
What actual modem/gateway is the RAX connected to in AP mode?
- The other router is a C4000XG, which I'm using as my CenturyLink gateway. Things worked _okay_ when I ran the network without it, but wireless was spotty in parts of the house, since the spot where the fiber enters the house is far from the best place for Wifi.
- Yes, I followed the instructions and very carefully rebooted each device in the right order to be sure. All the devices on the main network worked just fine with the exception of the RAX200. While I could see the wireless network, I couldn't connect to it (or its network) in any way.
While I could see the wireless network, I couldn't connect to it (or its network) in any way.How did you try to connect? Sadly "couldn't connect" tells us nothing about what you did and what happened.
In AP mode you can't use things like mynetgear.com.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
You need to work out which IP address the router has assigned to it. Something like 192.168.1.XXX
There are various ways of finding that out. The easiest is probably to login to the C4000XG modem/router – doesn't look like a Netgear device – and its list of "attached devices".
Then aim a browser at that IP address.
