Jimmy_W's avatar
Jimmy_W
Guide
Mar 23, 2022
RAX200 Latency issue for all devices if one device uses Wi-Fi Calls
Hi
I have the following setup.
Devices are connected to different bands.
Some devices on 2.4ghz, Some on 5Ghz and one device on 5Ghz with Wi-Fi 6 active.
Now when a mobile phone that is connected on the 5Ghz Standard band receives a call and have the Wi-Fi calls activated on the phone, then latency issue happens across all bands, huge spikes in latency for example on the device that sits on it's own 5Ghz band Wi-Fi 6, latency goes from 45ms to 200ms-800ms up and down until the call is completed.
Tested on iPhone 13 Pro, OnePlus 8 Pro, this issue happens as soon as the phone have Wi-Fi calls activated, turning that function of, no more latency issues. It's clearly something wrong how the RAX200 handles this data on the network.
  • Do you have Smart Connect enabled?
    What firmware version is on the device (not "the latest", a number)
    Do you have QoS enabled?
    What is the modem in front of the device?
