lazysusan111
Nov 15, 2020Follower
RAX200 Manual band selection while Smart Connect is turned on
Hi all, I really like Smart Connect in theory. However there are a few devices around my home (IoT, wifi-enabled speakers, etc.) that occasionally fail to work with smart connect. I believe the r...
Nov 16, 2020Guru - Experienced User
You can make the suggestion.
https://community.netgear.com/t5/Idea-Exchange-For-Home/idb-p/idea-exchange-for-home
But smart connect is designed for the router to control which device ends up on which band. You're right in that its not user adjustable.
