Steveosupremo
Oct 02, 2021Initiate
RAX200 no USA option
So I just updated to version 1.0.5.132 and after I updated I was not able to select America (USA) as the region.
I have lost a lot of WiFi range, and is just not good anymore.
Anyone know which version had America option?
and Yes, the router was from America.
Thanks,
Steve
Sort By
- psychopomp123Luminary
That's strange, my RAX200 (also purchased from USA) has never had the region/country selection option. Not on current (latest) firmware nor on previous firmwares. Where in the router settings were you able to select region on older firmware?
- SteveosupremoInitiate
This is in the wireless setup area. under advanced.
Ah yes I can see it now, but region setting is greyed out, ie its locked to region where you purchased it and cannot change it. AFAIK on the RAX200 its always been like that on all firmware versions. Do you not see the screen below?
