Retired_Member's avatar
Retired_Member
Nov 13, 2021
RAX200 not showing QoS speeds.
My RAX200 used to show internet speed per device.
This is no longer showing. All devices show 0.00 Mbps.
I've tried returning and using another RAX200, and for an hour or two it showed the speeds, and then after power cycling the router, same issue. Returned for yet another swap and same thing.
This is definitely some sort of firmware issue.
Firmware Version V1.0.5.132_1.0.69
What's going on here NetGear? Smiley Sad
  • plemans's avatar
    Maybe the version you're on has a bug. Have you downgraded the firmware?
    • Retired_Member's avatar
      Retired_Member
      Yes, I've tried this and same issue.
      • plemans's avatar
        what speeds do you pay for?
        That feature usually just displays the bandwidth you're on.
        And if you're paying for over 250mbps, it isn't recommended to use qos anyway as it can cause slow downs/latency
