wase471111's avatar
wase471111
Apprentice
Jun 07, 2020
RAX200 or Orbi ax6000?
so, been using the orbi wifi 6 3 piece system for a few months now, and only a couple of issues, like the random internet disconnects that are talked about all over the web...wifi speeds are fantastic, so I deal with the occasional internet drop outs but it can be annoying.
now, I see my second choice, the RAX200/AX11100 has dropped in price, and, seems to be really stable now after several firmware updates, so I was wondering if it makes sense to switch to that and get rid of the Orbi.
I would need a wifi extender to put in my garage for my POE ring camera, but I assume I would get enough coverage for my 2100 SF home and outdoor patio with the RAX200 by itself.
Has anyone switched to the RAX200 from an Orbi AX6000 system and been happy with the results?
Its great getting almost 800MB WIFI speeds on my GIG connection from Cox around the house with the Orbi system, but I am getting annoyed by the wifi drop outs with the Orbi system, and was hoping the RAX200 would be the answer..
Thank you for your feedback!
  • plemans's avatar
    I don't have the orbi AX but I do have the Orbi AC and I have the RAX200.
    If it was me? I'd stick with the orbi setup. Its a true mesh system with some bugs getting ironed out.
    It might take a bit though.
    The RAX isn't mesh and adding a mesh extender doesn't make it a true mesh.
    I actually went back to my using my orbi AC mesh versus my RAX200. I use the rax now for testing out AX devices.
    • Scottish's avatar
      Scottish
      Tutor
      Agree with plemans i don't have a mesh system due to vendor lock-in and different use case but do have the rax200. Had it since it came out and it has been very buggy. Until last week I ran it in AP mode with the 2.4 band disabled as it didn't work for me in any other config. It's back to router mode after the recent update in firmware but vlan tagging isn't working.
      on the mesh if you're not looking to do any radio segmentation/advanced networking and just want a fire and forget without anything too technical that has coverage over a large area then I'd go for that.  however bear in mind that it's a consumer solution and you'll be locked into Netgear (not a bad thing) for any extensions.
      really down to the use case to be honest.
    • wase471111's avatar
      wase471111
      Apprentice
      Yeah, its impossible to imagine anything being faster than the Orbi AX; the occasinal drop outs are annoying, and, the firmware, although better than at first, is still really buggy and lacking any sort of advanced features.
      I coulld sell my 3 unit orbi now for more than I paidf for it 5 months ago, so it is tempting..
      Problem is, not alot of folks have much good to say about the actual performancxe of the RAX200, so that is concerning..
      • psychopomp123's avatar
        psychopomp123
        Luminary
        Usually people only post on forums when they have issues with a product - the RAX200 is no different.
        I've had my RAX200 for a ~ 6 months ago and its the best router I've ever owned for wifi. Sure, there were a few bugs at the beginning but i find it rock solid now. The RAX200 is far more stable against Asus' offering, the GTAX11000, which is still buggy as hell despite Asus releasing a firmware update for it every 2 minutes.
