Memmaatre's avatar
Memmaatre
RAX200 PMF how enable?
Hi,
I cannot find PMF settings on/off on RAX200. Is it called anyting else than PMF?
Br Mem
  • plemans's avatar
    PMF is required for all newer certified devices.
    So its built in
    • Memmaatre's avatar
      Memmaatre
      Thanks but I read that it could be disabled also in RAX200 interface, Advanced/Advanced setup or something. Cannot find it.
      • plemans's avatar
        What are you trying to disable it for?
        Some models have that option. Not sure about the RAX200 though.
        Maybe a better idea of what you're trying to do and why might help us to help you
